Phantom 4 Firmware V.00.00 0000 Problem
6553 27 2019-6-30
Nrj Muhendislik
Flight distance : 1871119 ft
Turkey
While updating my Phantom 4 firmware with Samsung android tablet, process stuck at %99.
After that I try to update firmware via PC. But DJI Assistant 2 could not determinate firmware version. Also try with an iphone but nothing change.
Now i can not upgrade or downgrade my P4 firmware. RC linked with P4. Gimbal movement works. I can start / stop motors but not recive video transmission.
What should i do for make P4 work as before?
Ios
Ios
PC
PC
2019-6-30
sedeco
Flight distance : 8060653 ft
Egypt
hi  all i have same problem  now in p4  no picture  from camera and after check  see unknown   firmware   and stuck 99%  and no ip from p4 ftp
this problem  because battery  remove when update install
2019-7-12
Discokuningas
Flight distance : 16476 ft
Finland
Hi,
I have the same exact problem but the installation of firmware was cancelled due to network connection error. After that it continued the installation but got stuck at 99%.
RC has the latest 1.9.3 version and my android phone (Honor8) says P4 has the latest firmware but don't give any version number but when connected to DJI Assistant 2 for Phantom it says V00.00.0000.
I can still fly the drone but camera went grey after the failed firmware update.
2019-7-22
djiuser_NhfbUaNl7FUF
Flight distance : 115384 ft
Réunion
salut j ai le meme probleme avez vous trouvé une solution?
2019-7-28
Kuminatano
Flight distance : 154249 ft
Argentina
djiuser_NhfbUaNl7FUF Posted at 7-28 07:47
Hi everybody.
I have the same problem with a new PH4 STD.
Any solution?
Thanks! I' d tried everything.... with DJI assistant 2, with dumldore, etc.... and nothing...
2019-7-29
Réunion
help
2019-7-29
Gerou
Flight distance : 23 ft
Greece
Same problem...  00.00.0000, no  image from camera , drone can fly. the led near the sd card flashing green red yellow!
Any solution?
2019-7-30
Réunion
personne pour nous aidez?????
2019-7-30
giovanni974
Réunion
personne a trouvé de solution?
2019-8-1
adrian8891
Flight distance : 2643110 ft
Poland
Seems DJI doesn’t know solution
2019-8-2
giovanni974
Réunion
adrian8891 Posted at 8-2 23:41
J ai contacté plusieurs personne pas de reponse
2019-8-3
giovanni974
Réunion
toujours pas de solution?
2019-8-6
sedeco
Egypt
hi  only way  to write dump to emmc in main board   need eng to do it  by isp pinout  i got it after remove emmc
2019-8-12
giovanni974
Réunion
c'est a dire?
2019-8-13
sedeco
Egypt
what you mean ?
2019-8-14
giovanni974
Réunion
comment avez vous fait pour reparé votre p4
2019-8-14
sedeco
Egypt
giovanni974 Posted at 8-14 07:30
hi  i remove emmc from  error p4   and read it  by programmer  and  write good file dump from working p4
2019-8-17
Nigel54311
Discokuningas Posted at 7-22 22:30
Hi,
If any consolation, I have the same issue - was getting network connection issues, went through but stuck at 99% now only get : Firmware V.00.00 0000 - flying brick, all works with no video.
2019-8-26
giovanni974
Réunion
moi pareil
2019-8-28
Driller35
Flight distance : 1106 ft
Same cannot get it updated , and getting so many issues , no sd card  , overheat warning
2019-8-29
djiuser_5CSnGfQ1QE9C
Panama
having the same issue...any solution?
2020-1-24
Nrj Muhendislik
Turkey
We swap mainboard from a crashed and totaled same spec P4.
2020-1-26
fouzi
Good evening concerning this problem I saw a video on youtube as if this part must change to solve this problem
2020-2-3
paolivera
Flight distance : 121 ft
Argentina
ALGUIEN QUE DE UNA RESPUESTA COHERENTE???K DJI NOS DEJO SOLOS
2020-4-25
tellurian
Flight distance : 29938 ft
fouzi Posted at 2-3 16:13
Good evening concerning this problem I saw a video on youtube as if this part must change to solve this problem[view_image]
Nope. What you've shown is an ESC.
Misleading suggestion that does not help.
2020-5-15
Droneflier
Flight distance : 1811322 ft
South Africa
What App version is DJI Go on now for the Phantom 4
2020-5-24
djiuser_yIZcq5Stnmg2
Colombia
Does anyone have a solution to this?  I'm about to cry right now.
2020-11-2
Esdras Djamen
Quelqu un a t il trouve une solution. Aidez moi s'il vous plaît
1-9 15:03
