Benny84
Hi, a few weeks ago I had a fall with my mavic air. After the first moments of panic, I found the arm of the broken gimbal and an ESC error. I fixed the gimbal arm, but I still got the ESC error which doesn't allow me to start the drone. I disassembled the drone and did some tests and as I read from the different forums the error is due to an engine that requires more energy than the others in the same conditions. Is there a system (software or mechanical) to identify which engine is a problem and only replace that one? I don't want to have to replace all four of them unnecessarily. For completeness of information I did these tests: Turning on the drone all four propellers move correctly during the engine test before the ignition beep. After the attention beep (comparing it with another mavic air) the rear engines seem to move only partially. This gives me hope that at least the ESC logic board is safe. I tried to manually turn the propellers and it seems to me that all 4 engines offer the same resistance. I checked the copper filament of the rotor and they all look ok, no break. I also restored the drone factory settings. None of these operations eliminated the ESC error. How can I independently identify the motor arm that is giving me problems or if the error is due to something else? thanks a lot
