Matthew Dobrski
Flight distance : 1831050 ft
DJI Tony Posted at 7-3 10:19
Hi, thanks for the inquiry. The different lenses use different filters as well. the weight of filters also need to satisfy the demand, for Zenmuse X5S, third-party lenses also need to use the corresponding filter, the Zenmuse X7 series filters are not compatible with the Zenmuse X5S. Please check the screenshot below. Thank you for your support.
[view_image]
Whoa, Tony! Are you sure? X7 specifications are stating 46mm filter size for all X7 lenses, the same size for 15mm lens on X5S camera. How come these are NOT compatible, as you're saying? |
