Unable to load firmware
2247 4 2019-7-3
JasonPeters
I updated the firmware via the Dji4 app.  Then of course the camera stopped working and I was getting a weak transmission error.  I downloaded the Assitant 2 for Phantom and tried to change firmware via 3 different versions.  Every single one failed to upload.  shows my current version as all 0's.  If I link to the app, it does not show that the firmware is out of date.  I tried an android phone and Ipad.  Nothing works.  This happens far too often and its very frustrating.  What can I do?
2019-7-3
fans050c042b
Flight distance : 1621591 ft
I’m having the same problem. Phantom 4 Pro. No camera feed.  Controller also has red/green led flashing. The controller about shows 00000 initially for Aircraft  but if you check for update and leave for a while it comes back with 01.05.0600, go4 app ver is 4.3.14.   I understand it may be that the controller needs to be updated also. I have tried assistant 2 direct connect to controller but that won’t work, also downloading WM610_FLIR_FW_V01.31.00.60.bin file onto a sd card and put in back of controller and this does not work either. Is this the correct bin file for the phantom4 pro, should it not be called GL300...?  Help also
2019-7-4
fans050c042b
Ok after many hours I finally got it to work.  I can’t confirm if I updated the android screen of the phantom pro or the controller but I cleared all outstanding pending installations off the android device, rebooted and it told me it needed to update to V01.01.00.00
Once I did this I now get a picture and green led on controller
I suspect it may have been the android screen and OS that was causing the issue
2019-7-4
JasonPeters
Does anyone from DJI read this stuff???
2019-7-9
GNB
JasonPeters Posted at 2019-7-9 08:48
They probably do read these posts but DON'T Care... They have your Money and that's the end of the game for these folks !! ~~~
2020-10-18
