Tilt axis not smooth (glitches)
2101 5 2019-7-4
djiuser_8xVR8299k77X
Hello,
since a few weeks, when the titl axis is used, there is some glitches. The problem especially occured when the movement is slow.
Here a video to understand the problem. (I'm using the same pression on the joystick):
My balance test gave me "Excellent" on all 3 axis, I'm on the latest Firmware, and I also tried after an app reset, but still the same problem.
My Ronin S never fell or never took a hit, I'm not sure when that problem appears but I can't do nothing right now with the gimbal because those glitches will be visible on the video.
Any ideas ?
Here some screenshot from the app:
Screenshot_20190704-184255.jpg Screenshot_20190704-184358.jpg Screenshot_20190704-184310.jpg Screenshot_20190704-184319.jpg
2019-7-4
Andy Mihail
Romania
I'm not an expert, but try autotune on low.
2019-7-4
Yek
Andy Mihail Posted at 7-4 11:26
You made me think that I hadn't tried to proceed an auto tune, I did it and everything seems to be fine now !
Thanks !
2019-7-4
Neo Nyrox
Bonjour j'ai le même problème je ne comprend pas! Pouvez vous m'expliquer??
2019-7-7
Hi Yek, sorry for the late response, glad to know the issue has been figured out, hope you have a great time with it.
2019-7-8
Neo Nyrox Posted at 7-7 06:01
Hi Neo Nyrox, firstly, please make sure each axis has been balanced properly. Then make the Auto Tune in the APP to see if the issue persists.
2019-7-8
