DIY case for osmo action to fit in the usb-c charge cable.
2124 10 2019-7-6
Fsong
Flight distance : 7573041 ft
The original Osmo Action Case won't fit in the usb-c cable for charging.
So I made this DIY project by modifying an existing action camera case in order to address this issue.
I think the solution should be easy and cheap to do by yourself.
Thank you for your comments.
2019-7-6
DJI Gamora
Hi, Thanks for sharing this amazing DIY case for us. Thank you for your continued support. Cheers!
2019-7-6
ff22
Nice work.  I have thought of using the Dremel on the original case but am not rushing to do it (g)
2019-7-6
Fsong
ff22 Posted at 7-6 16:44
I had similar dilemma of whether to use the existing osmo action case or not. The surgery on the existing action casing probably is much more than the one in the video.
2019-7-6
David Martin Graff
Flight distance : 106566408 ft
Nicely done - thanks again for sharing!
2019-7-6
jacksonnai
Malaysia
Cool! Thanks for sharing
2019-7-7
Woe
Flight distance : 4129268 ft
Well done
2019-7-7
El Diabolico
Spend 20$ and get one of the several cases / cages available on Amazon...
2019-7-7
jefish
Why not just remove the USB-C door before installing the camera in the case?
2019-7-14
whatever...
Flight distance : 180994 ft
ok, nice; but...
all this non-sense would'nt be necessary if DJI just put a damn standard screw mount hole on the bottom. Would have added a few millimeters to the overall size, but certainly still be smaller than with all these cases! Why oh why?! Just so you can market more accessories!?
Very dissapointing!
2019-7-14
ff22
jefish Posted at 7-14 14:04
The door prevents water/moisture from entering the internals of the camera and also dust or grit.  So the option of opening the door while still inside the case can be convenient to copy files or charge the camera.
2019-7-14
