Programming Errors
811 2 2019-7-7
Bacardi251
Is anyone else having problems with the premade programs? The sequence attack program to be specific. The program was working perfectly fine, but now it isn't aquiring the targets. In addition, upon running, the gimbal travels 180 degree's to the left or right past the targets.
2019-7-7
Malibu Aerial
Flight distance : 143898 ft
Did you modify it?  Did you try both scratch and python?  By the way, mine is dated 3/27/19 which is the factory modification date.
2019-7-10
Rocky2
I have had some inconsistent results with sequence attack as well. I found distance to target, lighting and angle to be the cause in some cases. The AI recognition seems to happen extremely quickly if it's going to work; if the camera doesn't immediately recognize a "1" (or whatever number/symbol) in its field of view, it will hunt (180 degrees left or right) looking for it. For me, changing the lighting and location of the cards has had a positive effect on initial recognition - it can be picky.
2019-7-10
