Will MP2 respond to stick modes in active track?
871 1 2019-7-7
marklyn59
Flight distance : 395072 ft
If I'm using active track to follow something, will I still be able to move the drone up/down or use any of the stick command controls while it's actively following something (trace mode)?
2019-7-7
DJI Tony
Hi, thanks for the inquiry. The remote controller can be used while doing the active track, however, it would be a case to case basis depending on the sub-mode you've used under this active track. For further information, you may see the screenshot below. Thank you for your support.
2019-7-8
