D-Cinelike
917 2 2019-7-8
st599
Hi all,
Interested in using the DJI Osmo Action for a series of experimental shoots that I'm working on.
Would like to use one of the formats which captures a larger range of the sensor output and use the UHD and image stabilisation modes.  I believe this forces me to use D-Cinelike mode.
I will need to convert this to a standardised video format.  I have been unable to find any technical description of D-Cinelike, without which a correct conversion is not possible.
Could someone point me at the technical data for:
  • Primaries - CIE Yxy, CIE Yuv, CIELAB etc.
  • Matrixing for YCbCr to RGB
  • Opto-Electronic Transfer Function in use.
  • Reference levels for 18% Grey Card and 100% Diffuse White
Thanks In Advance
2019-7-8
fansf50d5338
Any update on this? Not being able to correctly convert to CIE XYZ makes these cameras less than useful.
2019-11-5
MKosmo
I doubt if you will find this sort of info for a camera in this market segment.
Is there something you could do to create your own transfer function using a known reference source ?
2019-11-5
