DJI Tony
Hi, we're sorry for the inconvenience. Like Djlee0314 mentioned, did you manage to turn-off the beginner mode? Did you manage to update the firmware of your aircraft? For additional information, please ensure that the remote controller is on P-mode and the aircraft is detecting enough GPS signal in an open area environment. You may consider uninstalling and re-install the application or change the mobile device to isolate the situation. Kindly ensure that the important files are saved and flight records were sync prior to deleting your application. You may refer to the link below. Thank you for your support.
