Hi Aerial Pros, sorry to the troubles with the Inspire 1, how far can the drone fly when this message comes up? What mobile device are you using? Please use the mobile phone with strong decoding performance.
Does the issue happen in every place and every time? Please try to test the aircraft in different flight environments.
Please adjust the position of the antennas:
a. Open up the antennas on the remote controller to optimize the transmission range. The flat surface of the antenna should be facing the aircraft.
b. Keep the antenna parallel to each other.
c. Check whether the antennas are damaged.
We recommend to fly in Auto channel.
Is your firmware the latest version and whether the aircraft has cosmetic damage, such as crash? |
