Dji Ronin M facing the wrong way
3317 5 2019-7-12
lachie1
As seen in the video... as of recently when i turn on my ronin m it spins around and faces the wrong way. I've sort of ignored it since It doesn't seem to have any effect on peformance although I've been curious as to why this happens and how to 'fix' it. Before you ask yes the safety clip is facing the right way and is clicked into place https://youtu.be/ZAwWqugH5oA
2019-7-12
DJI Thor
Flight distance : 13602 ft
Hi lachie1, sorry for the late reply. Please try to enable SmoothTrack on the gimbal settings and set the speed to 100.
Besides, please kindly provide the data of the attitude after powering on the gimbal for further checking. Thank you.
2019-7-16
lachie1
DJI Thor Posted at 7-16 03:22
I set the smooth track speed to 100 but nothing changed. What is "the data of the attitude" and where do I find this information?
2019-7-19
DJI Thor
lachie1 Posted at 7-19 02:29
Please tap motor specifications, then more, thank you.
2019-7-21
lachie1
DJI Thor Posted at 7-21 18:47
I couldn't find 'motor specifications' anywhere however I connected my Ronin M to my computer, updated some firmware and it seems to have fixed itself and is now facing the correct way.
2019-7-23
DJI Thor
lachie1 Posted at 7-23 21:40
Sorry, I should've made it more cleary, it's in the DJI Ronin Assistant app on the mobile device, tap motor, then you'll be able to see the data. You can take the screenshot below as an example. It is good to know that you had got it worked again now. If you still encounter the same problem, please kindly provide the screenshot of the data for us to check further. Thank you.
2019-7-25
