Sick Dog
Flight distance : 451119 ft
Bluehook Posted at 7-21 09:10
I have been continulously frustrated by this exact issue and have yet to find a satisafactory solution.
Question: Actions settings do not load on to the drone, we know this -- but I think, your heading setting does. So, picking an average pitch/angle of the camera and turning your heading to correlate with the POI's you wanted to use, might work pretty well and be the closest remedy.
Litchi loads the mission into the drone, actions do load with the mission created but only work with straight path missions. Curved flight missions can not use actions, except for the first and last waypoints to start and end video recording.
To use gimbal pitch in curved path missions you set a series of poi's along the path of the mission flight, and use the relative elevation of each poi to control the gimbal. The poi's elevation is set by default to 3 ft. You can change the height of where the gimbal will focus on the chosen poi by raising the poi elevation height or lowering it to whatever you choose.
Say your chosen poi is 20ft tall, the poi's default height is agl 3ft, but you want to focus on the agl 10 ft portion of the poi, you set the poi elevation to agl 10ft and the gimbal will move to focus on this approx point, due to the map data it uses. You do this in the poi settings, this happens during flight from waypoint to waypoint. This means if your drone is flying from wp 2 to wp 3 and your chose poi 6 to focus on at agl 6ft, as the drone flies to wp 3 the gimbal will start to focus on poi 6 as it flys from wp 2 to wp 3. say you flight from wp 1 to wp 2 is north to south your wp agl is 100 at wp 1, you choose agl 5 for poi 8 for wp 2 and you want to climb to agl 250 the gimbal will then start to focus on agl 5 on poi 8 as the drone flies from wp 2 to wp 3 as it climbs to 250 agl. the drone then flies on to wp 3 and so on with smooth cinematic transitions. hope that's not to confusing. It really works and looks good.
Actions allow you to start stop recording vids, take pics, set interpolations etc but only with straight path flights you can set actions to yawl or turn right or left climb or lower as it flies, or you can manually control those actions instead of using actions.
Litchi is very powerful, you can use the web portal or the app to create missions, the web portal is where you can set all the controls for curved missions, and set actions for straight path missions. hope that helps. phantom film school on udemy will teach you how to do this and lots more.
Hoping to go out to meteor crater if the winds die down and shoot a curved flight. it's so windy here I get out once a week or once every 2 weeks.
