Cetacean
Flight distance : 2528264 ft
Aloha Bashy,
In the past, there have been flight options listed that were not enabled until DJI added them to the flight software or firmware. With the P4, I have had a number of problems including not being able to Activate it when I got it. Then there are all the problems we have dealt with helping others on the Forum. But, you are right that a non-functioning listed option is a rarity.
For months, I had WayPoints listed but it would not work until the Firmware was upgraded. It all worked eventually. I think I remember DJI had to deal with an overriding security issue before they could solve the problem, but they did. I just used Litchi until the problem was solved.
But, I do remember DRAW being limited to specific Phantoms at one time and my TapFly just did not work. But to be honest, I cannot remember which Phantom had the problem or if it was the same Phantom that had the problems. I still have to check my P4 on those two flight options.
The first Phantom I had that could make TapFly work was my P4 Pro and that was a lesson. I sent the Phantom way back into the valley while trying to do a 360 video like using CourseLock. Not the same, and I ended up almost rear-ending the near-vertical ridge on the side of the valley. Boy, was I ever happy for the rear Vision System and its Obstacle-Avoidance function. One of the many times I have lucked-out as I have learned.
Good hearing from you again!
Aloha and Drone On! |
