Sean-bumble-bee
Flight distance : 15997 ft
djiuser_1UwZmTtrgukr Posted at 12-30 05:11
Bro you can go and check for the glue that comes on the top of one screw of the frame, if it has a small glue that it looks like a small amount of silicone on the top of the screw then you’re good to go with it, because if it has crashed before then it must been disassembled before, and to disassemble the drone you should take of the glue on top of the screw using the screw driver. Dji like any other manufacturers do that hack in case of a guarantee charge to check if there products have been maintained by other technicians.
One screw with a glue on the top of it = never has been disassembled or repaired
Though what you say is correct, do you realise you are replying to a three year old thread? |
