JohnDG
Flight distance : 1097270 ft
Belgium
Are you sure the mavic, the smart controller and stock controller are all on the latest update?
Also try to install the latest firmware again, using the dji assistant 2. I once was able to solve a problem by installing the same firmware with the assistant 2. Sometimes the firmware image is not installed completely. Restart the device after upgrading.
Good luck |
