Wiring error during the build, robot turns backwards
LTrain
Flight distance : 91919 ft
Somewhere along the way we made a wiring mistake.
In FPV model the robot turns left when we move the stick right and vise versa.
Coding up a simple program in scratch has the same effect.
So clearly we got two wires crossed in the control module.
Is there a wiring diagram for the four wheels that shows the correct inputs?
2019-7-16
LTrain
Figured it out we put the wheels on backwards even after I called myself checking gfor that...
2019-7-16
daev2018
Flight distance : 12263747 ft
I have the wheels on correct but I have to slide the left control pad down to go forward. Is that correct?
2019-7-19
Saberfly
What you need to do is re learn the wheels step. I didnt notice it on the screen but when it prompts you to spin the wheels 3 times, one side shows to turn them backwards. I didnt notice it the first time either but when I re did it, mine worked fine. Let me know if it helps you.
2019-7-19
Malibu Aerial
Flight distance : 143898 ft
daev2018 Posted at 7-19 15:00
The wheels are not the same. 2 clockwise and 2 counter clockwise. You must have mixed them up.
2019-7-20
Saberfly
Mine did the same thing and they were on right.
2019-7-20
djiuser_LXNCTQ1omKMP
Flight distance : 46155 ft
My robomaster’s left and right is fine but it’s it able to move forward or backward
2019-9-23
Duane Degn
djiuser_LXNCTQ1omKMP Posted at 9-23 11:51
Have you tried addressing the motors in the app?
From the "Solo" FPV screen tap the "Settings" icon in the top right.
Select "System" and then use the "Motor Addressing" feature.
It looks like your wheels are on correctly. The rollers should make an "X" when viewed from the top.
2019-9-23
Duane Degn Posted at 9-23 12:02
After motor addressing the movements are working as intended. Thanks for the help!
2019-9-23
