Mirek6
Flight distance : 609724 ft
LongArm Posted at 7-17 10:18
Thanks for the tips! I will try compass re-calibration in a more remote area. I'd been putting that off because so many posts say not to re-calibrate the compass unless instructed to do so by the app.
If compass re-calibration doesn't help, I will try re-flashing.
Yes - cell phone towers have been reported on this forum in the past to cause issues.
Usually these issues were different than yours and related to interference of RC / AC communication.
However Spark is a complex beast and its systems are susceptible to magneto-electric interference. Despite awesome and cutting edge technology, it is a cheap drone so, naturally, it is not as resilient as its higher priced cousins.
I would stay away from towers, high voltage lines etc.
In any case - the advise you are seeing on this forum not to calibrate when not prompted by DJI GO app is a sound one since bad calibration can cause a lot of issues. However... when you experience issues, especially something which you described which is very consistent with bad calibration, do not hesitate to re-calibrate. Both IMU and compass. But do it properly - as described.
Yes - if careful and proper compass and IMU calibration does not help - re-flash. Firmware may have gotten corrupted. And if this does not help either - contact DJI support. Although, if your Spark is second hand, you are probably out of warranty :-(.
Good luck and please let us know of your success.
Mirek |
