Virtual Joystick ?
3770 14 2019-7-17
jiD One above all
Flight distance : 137388 ft
Denmark
After updating the ronin s-sc App
The Virtual Joystick when pan left and right ind App , the ronin s gors in opposite direction ?
pan Right ( Virtual Joystick ) the Ronin s goes Left and ........ Yes I can put my phone upside down and we are back to working order
Even if you for this in Control settings it doesn't change ?
Is this just a little Error from now ?
App Version 1.2.0(124)
Firmware : 1.8.0.70
Please pass this along to your engineers ;O)
88888888
2019-7-17
Hi there, could you please double check if the joystick is set to Reverse in Control Settings--Channels of the APP?
2019-7-18
jiD One above all
Denmark
Hey Mindy
Reverse in Control Settings--Channels of the APP ,does not make any difference
have a try on 5 difference Ronin-s and phones
everything is the reverse
2019-7-18
jiD One above all
Denmark
for info
has tested it with iphone-ipad´s and android.
everything is
Reversem in App ( Virtual joystick )
after updating the App
:O)
2019-7-19
StewartWood
I'm having the same issue since updating the app. Also, get "Please connect dedicated cable to RSS port for this feature" when I never did before the update.
2019-7-23
userd75357218c
I am having the same issue, the virtual joystick works in reverse mode for pan and tilt
2019-8-19
jiD One above all
Denmark
userd75357218c Posted at 8-19 21:44
Yes this has been problems since last updateYes this has been problems since last update. Solution rotates phone
haha not a fix; O).  It's been 100 years since there's been an update  Or they feel there ;)  GOGo DJI  please update please ;)
2019-8-20
OVER
Belgium
Hi
is there any solution to that matter please ?
I am using an iphone app.
2019-8-22
jiD One above all
Denmark
OVER Posted at 8-22 15:25
Hi
Unfortunately not now
only rotate its mobile 180* haha not a fix yet ;)
2019-8-23
IJD One above all
Denmark
DJI Mindy Posted at 7-18 01:42
The update on the app solve the problem with the joystick thanks. Took some time but thanks ;O)
2019-8-28
IJD One above all
Denmark
app 1.2.2(126)
2019-8-28
IJD One above all Posted at 8-28 09:23
app 1.2.2(126)
That is great, hope you have a great time with Ronin-S.
2019-8-30
IJD One above all
Denmark
DJI Mindy Posted at 8-30 01:24
you can believe I have:O) , i have worked with a rig stedicam like alot of time  & now I rockning  my Ronin's
100%
2019-8-30
IJD One above all Posted at 8-30 01:51
100%
Glad to hear that, looking forward to some great footage from you.
2019-8-31
IJD One above all
Denmark
DJI Mindy Posted at 8-31 02:42
2019-9-2
