What Are the Best Settings For Shooting While Walking?
10763 29 2019-7-18
JDVideo
I'm wondering if there is a best setting for using the Osmo Pocket while walking: Tilt Locked? Follow? FPV? Along with either fast or slow follow? I want the best setting that will allow the lens to keep straight ahead and come to the straight-ahead position after turning a corner, for example, all the while holding the camera steady and not moving the arms. I find that for whatever reason, when I make a turn, the lens does not come right back to the straight forward position it was in before making the turn. It's slightly off center. I don't want to do a re-center while walking as that will cause a quick jerky segment in the video. But it seems that the only way to bring it back is to slightly twist the wrist. I'm new to this camera and not familiar with a gimbal operation. Perhaps this is normal for a gimbal, I don't know, but it would seem that the lens should keep track of its position.
Thank you for your help.
2019-7-18
hallmark007
Flight distance : 9827923 ft
Sweden
Tilt lock is probably your best bet, but to avoid 4th axis up and down you need to perfect heel to toe walking , it does seem when panning camera returns off centre if you had control wheel you could use the lock button and just pan with camera locked , not sure why there is no camera lock on OP this is a feature of every other Osmo .
2019-7-18
JDVideo
hallmark007 Posted at 7-18 03:47
Thank you for replying. I appreciate that. Question. If you were to use a lock button, would that not defeat the purpose of the gimbal and therefore have unstable results?
2019-7-18
hallmark007
Sweden
JDVideo Posted at 7-18 04:02
It only keeps camera locked to centre or position you lock in to, so other axis still operate so footage is still stable .
2019-7-18
Tactical Trvlr
Flight distance : 255407 ft
I mostly shoot in follow mode and I get pretty good results. The more you use the Pocket, you will get the hang of walking with it. Just like any gimbal, it takes practice to get the best footage.
2019-7-18
fansfe82067d
"Lock" means locking the camera head relative to the scene, not relative to the handle.  So for instance, Tilt Lock means that  the head will point at the same place in the scene even if you tilt the handle.
Here's my standard explanation of the lock modes, if I may be permitted to post it again -
In FPV mode (which should have been called 'Unlocked' mode), the gimbal head will follow the direction of the camera handle without restriction - though the movement will be smoothed.  It means that the Pocket will behave like any other camera, apart from the smoothed movement.
In Follow mode - which should have been called 'Horizon Lock' mode - the gimbal head will always stay horizontal.  This means that you don't have to worry about keeping the horizon straight.  The camera will look after itself in that respect, and that's handy because with the tiny screen, it's hard to tell if the horizon is exactly straight or not.  Note that "Follow Mode" has nothing at all to do with tracking a face or other subject.  This mode is perhaps the most often used.
In Tilt Lock mode, which should have been called 'Tilt and Horizon Lock' mode (except that's too long) the camera behaves the same as in Follow mode (horizon always straight) but in addition, the gimbal will point ahead in one direction.  If you move the handle, you won't be able to point the camera up to the sky or down to your feet.  You can set it to straight ahead using the 'recenter' option, and you can adjust it down to your feet or up to the sky using the little slider on the right side of the screen.  It will then stay pointing at the sky or your feet (or anywhere between) regardless of handle movement.
In all these modes, it's always possible to pan the camera from side to side.  If you want to lock that axis as well as the axes locked by Tilt Lock, you'll have to use the controller wheel accessory and hold down the right hand button on the controller.  That makes the camera point in a constant direction, regardless of how you move the handle, thus preventing panning.
Hope that helps.
2019-7-18
David Martin Graff
Flight distance : 106566408 ft
How does the camera stay when not being used?...
2019-7-18
JDVideo
hallmark007 Posted at 7-18 04:11
That's interesting. So by using that lock on the wheel, one can still walk and make a turn with the camera and the lens will remain where you want it. But if you do make a turn like that, I would assume then that the video would not be jumpy like it normally appears as the lens tries to right itself. I noticed that when I played back the video. As you are turning, there are jumpy segments as the lens tries to catch up. Rather annoying, so hopefully using the lock on the wheel, that won't happen as long as you make your turn nice and smooth. Have I understood that correctly? Thank you for assisting.
2019-7-18
JDVideo
David Martin Graff Posted at 7-18 04:27
If you mean when I turn it off, it parks normally.
2019-7-18
JDVideo
fansfe82067d Posted at 7-18 04:25
Yes that does help. Great explanation of each mode. I was thinking of an OP that I had to return. When playing back a video clip using the FPV mode, I would hear a clanking or clacking sound while walking along.
So any of the modes should work fine. Perhaps either "Follow" or "Tilt Lock" should be the choice.
Thank you for this explanation. Very much appreciated.
2019-7-18
hallmark007
Sweden
JDVideo Posted at 7-18 05:46
Yes that’s how it will work, but as with everything it’s the fine touches and movements you make yourself that will insure good footage .
2019-7-18
JDVideo
hallmark007 Posted at 7-18 06:00
That's great to know. I will order the expansion kit that comes with the wheel.
Thank you.
2019-7-18
fansfe82067d
I guess my only thought is that the new expansion rod has the same functions as the wheel, with the addition of one more function, and uses a more intuitive joystick rather than the wheel.  But it's not exactly pocket sized!  And it looks like you really need the wireless adapter to go with it.  Sigh.  There's always one more thing to buy...  but I think every accessory I've bought adds a little more creative possibility to the Pocket.
2019-7-18
JDVideo
fansfe82067d Posted at 7-18 06:38
You got that right. There's always one more thing to buy, and you quickly discover that after you use the camera for awhile.
2019-7-18
DJI Gamora
Hi, Thank you for reaching out. Hope that you could get the best recommendations from our valued DJI members here in Forum. Cheers!
2019-7-18
David Martin Graff
Ah I see. Thank you!
2019-7-18
JDVideo
DJI Gamora Posted at 7-18 08:23
They are a great help. Very much appreciated!
2019-7-18
John Walker
JDVideo also asked about fast or slow follow setting for best walking results.  Which do other users find best?
2019-7-18
fansfe82067d
Slow, to dampen pans (and other movements) as much as possible.  Unless you are trying also to follow the meanderings of an active dog or something.
2019-7-18
John Walker
fansfe82067d Posted at 7-18 13:49
Thanks
2019-7-18
DJI Gamora
JDVideo Posted at 7-18 12:38
That's great to know. Please don't hesitate to reach us if you have any inquiries or concern. Cheers!
2019-7-18
JDVideo
DJI Gamora Posted at 7-18 15:14
Thank you, I will. I appreciate everyone's help. When you get a new product, it's nice to know that there are those who wish to help and assist.
Cheers!
2019-7-20
DJI Gamora
JDVideo Posted at 7-20 05:20
Cheers!
I agree with that. Thank you for your continued support!
2019-7-20
JDVideo
DJI Gamora Posted at 7-20 09:44
You're welcome.
2019-7-20
DJI Gamora
It's always our pleasure. Happy filming always!
2019-7-20
JDVideo
DJI Gamora Posted at 7-20 14:26
Loving this camera!! I can't image what DJI will come out with next. Great innovators. Their engineers are tops, for sure.
2019-7-21
El Diabolico
Ninja or catwalk...
Also shooting in 30fps and editing in 24fps will smooth the footage a little bit without been slow motion. Voices will get slower also so not recommended when filming/interviewing people.
Follow mode works fine.
2019-7-22
DJI Gamora
JDVideo Posted at 7-21 04:27
Thank you for your appreciation. Regarding DJI's future products, please stay tuned to the latest news and events by subscribing to DJI official website at www.dji.com or following us on social media platforms below. Thank you for your continued support!
Facebook: https://www.facebook.com/DJI
Twitter: https://twitter.com/djiglobal
YouTube: https://www.youtube.com/user/djiinnovations
2019-7-23
JDVideo
DJI Gamora Posted at 7-23 11:15
I’ll have to check the website. I don’t do social media. Huge time waster.
2019-7-23
DJI Gamora
JDVideo Posted at 7-23 13:33
That will work. Thank you!
2019-7-24
