BobMutchSD
Flight distance : 74623 ft
Troubleshooting steps: 1. Physical inspection - Are props and motor areas clean and undamaged? 2. Aircraft and Software up to date? 3. GPS - Do you have GPS lock (green/ good to fly)? 4. If connected to WiFi, Are you in a high interference area? 5. Are DJI Go 4 settings close to original? If motor gain settings are set in some odd way, the mavic might experience drift.
I would try Mavic in gesture/smart capture mode, to isolate physical issues first. With controller and phone off, turn on mavic. Wait for beeps, and gimbal adjustment, then tap rear button twice. Stand about 8 feet in front of mavic, and raise one palm from waist high, to head high. Does the mavic take off, and hold? If so, try bringing both palms together, and slowly drawing them apart, then together. To land, bring one palm slowly to the ground. Keep trying, sometimes it takes a couple tries. Does mavic move farther and closer? If this all works, then the issue is in controller/phone settings.
Good luck, and happy flying.
