AlansDronePics
Flight distance : 814751 ft
Guernsey
The manual warns you about the acceptable battery temperature during use. Next time, look at the battery temp in the app, during flight and make certain you don't exceed the limit for your model. The more power you use, the hotter the battery insides get. Even in the UK at 30C, the battery temp will climb to 45C with gentle flight.
Use the app and keep below the max temp and your batteries will last. This applies to all uses for lipo and is a chemistry thing, not a design fault. |
