Jay Blanton
Flight distance : 2475466 ft
This drone has been a WORKHORSE for over a year, with daily flights, sometimes more, and it's NEVER given me a single issue... but on the past few flights after removing the battery, I noticed some cracking where the top shell meets the bottom at the battery compartment. My question is, being how this isn't any kind of load bearing area & it's nowhere near where the battery grabs to keep it in place, is this OK to keep flying? It slowly gets a little worse every few flights and the opposite side is showing signs of starting to do the same. I've got my moneys worth out of this drone many times over, and I have a Phantom 4 Pro Version 2 with less than 20 flights that i'll start using if this one gives an issue, so i'm not going to send it in, but I just wanted to check on here to see if this will end up affecting the flight or battery in any way? Thanks!
P4P Cracking
