AlisaJ21
India
djiuser_LT8n2oYNfwcr Posted at 2022-6-20 06:18
hello,
Very sorry to bump in this thread with non related issue. i am new to the forum. is there any way to start a thread regarding my problem with the start button on rsc2 which is stuck ? it seems that new members can't create threads.
I searched on every forum on internet and eventually end up fixing this by working, there are a few steps you can try to fix it:-
1. Restart Your iPhone Using AssistiveTouch:- As mentioned in the previous response, you can use AssistiveTouch to restart your iPhone without the power button. Follow the steps provided earlier to enable AssistiveTouch and restart your device.
2. Update iOS:- Ensure that your iPhone is running the latest version of iOS. Sometimes, software updates include bug fixes that could address issues with hardware buttons.
3. Reset All Settings:- Go to Settings > General > Reset > Reset All Settings. This won't erase your data but will reset all settings to their default values. It might help if the issue is caused by a software glitch.
4. Calibrate Your iPhone's Battery:- Sometimes, a battery calibration can help resolve issues with hardware buttons. To calibrate your iPhone's battery, let it drain completely until it shuts down, then charge it to 100% without interruption. This process may take some time.
5. Use AssistiveTouch as a Temporary Solution:- If the power button remains unresponsive and you can't get it repaired immediately, you can continue using AssistiveTouch as a workaround for accessing power-related functions.
Remember that attempting to repair your iPhone on your own may void its warranty, so it's generally best to seek assistance follow below.
https://www.youtube.com/watch?v=WHzMvoTw5oo&ab_channel=TheGeekPage |
