hallmark007
Flight distance : 9827923 ft
likhan Posted at 7-22 12:44
Hi jjb,
Thanks for the validation. Indeed pre flight check is missing, still a newbie. Do you think this would have been found on a pre flight check? If yes, then I will create a feature request to the app. Also what would a proper list of pre flight checks? I have watched a few videos on that. And have done so on earlier flights. This one I guess i was just very excited to show off my new toy.
This link might be of some help, although checks are for professional you can take out of it what will suit you, will also leave a good practice preflight exercise which I have used for many years with great results.
https://forum.dji.com/forum.php?mod=viewthread&tid=152011
Tip To Help Avoid compass interference and crash.
1/ Never calibrate Compass unless prompted to.
2/ start AC leave until you receive enough gps lock ,
3/ if you get Compass interference turn off AC and move to another location,
without interference.
4/ In bottom left hand corner on your map you will see small red triangle, check to make sure that this triangle is pointing in the same direction (heading) as your AC, this will show good compass on the ground.
Raise AC to height of 8ft
Hover for 20 seconds
Fly forward 2ft
Backward 2ft
Left 2ft
Right 2ft
Up 2ft
Down 2ft
Yaw left
Yaw right
Each time returning to hover position
If you have a good horizontal each time, you will then know you have good GPS good IMU and good Compass, and your ready to fly.
This exercise takes less than 2 minutes and is worthwhile doing before every flight, |
