Wolferl
Flight distance : 23793 ft
Austria
Hi Rob,
Being in the UK, you suffer from low transmission power allowed in Europe.
If you fly in urban areas, you also range also suffers from interference from nearby Wifis, mobile phone, smart watches and so on.
If you fly, you should definitely turn off mobile data on your phone, and also for any bystanders.
An OTG cable does help too.
If you fly in more rural areas, where it is not likely that you will disturb anybodys Wifi connections, you can try the MOD 2.0 app (google it) instead of the the stock DJI Go 4 app. The MOD 2.0 gives you 600mW of transmission power (FCC rules) instead of 25mW. I'm using it all the time and am happy with it.
Also make sure you oriented the RCs antennas correctly (not pointing tips towards the drone).
Cheers,
Wolferl |
