elsegunzo
Flight distance : 278241 ft
Belgium
DrMrdalj Posted at 2019-7-25 18:27
1. No, you don't need any antenna extension - antennas are already extended. 2. DJI Pilot has mapping functionality so you can use it "out of the box" with supplied Crystalsky monitor. If you preffer any other app you can use mobile device hilder and app of your choice - M210 RTK V2 is not different then M210 V2 beside positioning module (that you can set beforenad in Pilot app)
PS I fly M210 RTK V2 with all bells and whistles
Hello DrMrdalj! Can you explain how you get the M210 RTK V2 operational with full bells and wistles? I've not been able to map a field using RTK and both camera's simultanious. Most third party apps do not support RTK.
RTK positioning works fine when I use DJI Pilot on my CrystalSky or with DJI GS Pro on my iPad. However, I have not yet succeeded in recording images from both cameras. It only records images from the first gimball (Zenmuse X4S). On the seconds gimball there is a Zenmuse XT, but it doesn't record anything during a mission. I hope you can give me some helpfull tips. |
