JayCrawford
Kinematic Digit Posted at 7-25 15:00
When I turn it on it gives me a solid yellow to indicate it needs calibrating.
Don't connect the camera to the multi-splitter and start it up and see if you get at least the solid yellow light. If that doesn't work, check the switch at the bottom the focus wheel, and make sure it's on S-Bus, not on Can. Then turn it all on again and see if it works for you.
Weird, yeah no luck – I've tried all kinds of stuff. Turning things on in different order, plugging them in in different order, switching to both S-Bus and Cam and still stuck with the red light. Tried without the camera plugged in as well |
