Dedicated cable needed?
9694 7 2019-7-27
StewartWood
I brought the Ronin S a couple of weeks ago to use with my Canon 80D which is not fully compatible. I used the track mode perfectly ok before the latest app update to control the gimble for product B-roll video. Now, after the latest update, all I get is this error message "Please connect dedicated cable to RSS port for this feature" This worked fine before the update.
Any help would be appreciated.
2019-7-27
Adrian Rydz
Japan
Same error message today... Track mode doesn't work with my Nikon D750.
2019-7-28
StewartWood
Any news on this?
2019-8-3
djiuser_dvAFB94oqAYF
I bought the ronin sc last week. I unboxed it today and now I am very disappointed because the trackmode doesnt work.
the track mode was one of the most important feature why i bought this gimbal.
I'm using the olympus cam. I wanted to use this finction without a kompatible cam.
2019-8-12
Droesch
For my Ronin S the warning only shows if i try to press the red record button on the app. Using the cable included with the Ronin to connect to my 5DMIV gets rid of the warning.
2019-9-26
Mortar Mike
Flight distance : 28327 ft
So TECHNICALLY the issue most folks are running into is they're pressing the red record button on the app itself.  That's technically telling the Ronin S that you want to RECORD from the Cell Phone itself, so it's confusing the Ronin.  For this to work properly, you'll need the cable that connects your camera to the Ronin S.  Once that's installed, and you have Activetrack visible on your cell phone, Press the Record button ON THE RONIN S, and not on the cell phone.
For best results, make sure that your cell phone camera is as in alignment with your actual lens as possible, or it will not easily follow them if they get too close or far.  You can also micro adjust AFTER you've selected your target for tracking with the joystick on the Ronin S, as sometimes they may appear too high or low in video.
PRO TIP:  The best way to work around this is to record at eye level.  Although this angle isn't ideal, it'll remove the too high or too low shot you can get from typically lower shots.  You can also use the Focus Wheel for native lenses with internal motors, or just adapt the Focus Motor to the ZOOM portion of your lens to pop in and out as needed.  It takes a little practice, but it's an AMAAAAAAZING tool once you get the hang of it.
2019-10-14
Mortar Mike
So TECHNICALLY the issue most folks are running into is they're pressing the red record button on the app itself.  That's technically telling the Ronin S that you want to RECORD from the Cell Phone itself, so it's confusing the Ronin.  For this to work properly, you'll need the cable that connects your camera to the Ronin S.  Once that's installed, and you have Activetrack visible on your cell phone, Press the Record button ON THE RONIN S, and not on the cell phone.  For best results, make sure that your cell phone camera is as in alignment with your actual lens as possible, or it will not easily follow them if they get too close or far.  You can also micro adjust AFTER you've selected your target for tracking with the joystick on the Ronin S, as sometimes they may appear too high or low in video.  PRO TIP:  The best way to work around this is to record at eye level.  Although this angle isn't ideal, it'll remove the too high or too low shot you can get from typically lower shots.  You can also use the Focus Wheel for native lenses with internal motors, or just adapt the Focus Motor to the ZOOM portion of your lens to pop in and out as needed.  It takes a little practice, but it's an AMAAAAAAZING tool once you get the hang of it.
2019-10-14
djiuser_PAxEn9ScDCmu
Philippines
here's what i did after getting the same error: (1) Connect app to gimbal, (2) Conmect camera to gimbal, (3) Launch Active Track on app and center subject, (4) once ready, hit "TRIGGER" once. All set.
2021-12-23
