Gimpy
Yes, thanks, the second one is the correct one. Unfortunately, it looks like you brought your drone down pretty close to the surface of the water and pulled back on the left stick when VPS indicated (perhaps incorrectly) that you were just a few feet above the surface of the water. With Landing Protection turned on, it initiated an auto-landing just as it does when you're directly above solid ground and pull back on the throttle.
This is actually the second thread like this I've seen in the past week, so you're not alone in making this mistake. The VPS sensor is used to determine how close to the surface the aircraft is, and it's less accurate when flying over water, so it may be that in reality you were more than three feet above the surface. Ultimately what matters, though, is that it thought you were close to a surface you wanted to land on, and you didn't cancel the landing (by pushing forward on the left stick) before it reached the water.
I'm sorry for your loss, but DJI does warn about flying over water and the lack of VPS accuracy there, so their decision doesn't seem unreasonable. Were you offered any sort of discount on a replacement drone? That's a common (but not universal) practice in these cases, and you may be able to ask for and receive it if it wasn't already offered. |
