Trying out Follow Mode
gpvillamil
Flight distance : 210226 ft
Tried it out on Treasure Island, it does a really good job when the lighting is good, and it can certainly keep up. I set the speed to Fast, and got about 40 minutes of battery.
2019-7-28
DJI Stephen
Hello and good day gpvillamil. Thank you for sharing this video and for sharing your experience in using the DJI Robomaster S1. It is great to see you in the video and thank you for your support.
2019-7-28
MarkusXL
Excellent test, good data.  Wondering how to use this feature in our own programs...
2019-7-29
rhoude57 - YUL
Thanks for sharing! That's one of the functions I haven't tried yet.
2019-7-29
Malibu Aerial
Flight distance : 143898 ft
I tried having the S1 follow an RC truck but it won't recognize it.  Maybe one day it will be able to follow anything other than a person.  Cool video.
2019-7-29
MarkusXL
Malibu Aerial Posted at 7-29 12:47
Lol -  dude, that is genius. Just put a picture or some cheap image or construct that looks like a person, for example, head, shirt, arms, pants, and the S1 will follow that, along with the RC car.
Write a short program that does person follow detection mode, and observe when, and when not, the AI has recognized a “person.”   I don’t think this AI is that smart, a mock image or a doll should be able to fool it.  Attach recognized image or dummy to RC car and go.
Hmm I wonder if it can be programmed to follow a Vision Marker?
2019-7-29
jacksonnai
Malaysia
Cool! Thanks for sharing
2019-7-29
MarkusXL
YESSS!  The S1 of course can Follow those Vision Markers!  In the Road to Mastery, there is code to make the gimbal track the Vision Marker - you hold up the Marker and the S1 tracks it.
Just a little bit more code and the chassis will drive to where the gimbal is pointing - right to the Marker.
Ok, this is going to be my next or after next project.  I have a RC car, going to tape a Vision Marker on it... let's see what happens...
2019-7-30
Malibu Aerial
MarkusXL Posted at 7-30 09:49
Let us know how it goes.
2019-7-30
MarkusXL
Malibu Aerial Posted at 7-30 11:06
Oh yeah - I'm gonna sink my teeth into this one.
Step one, create blank repository and put in the core bits.
Maybe tonight I can add the bits from the Road to Masters - Vision Marker Tracking
Here is the repo:
https://github.com/markind69/Vision_Marker_Chaser
So the idea is to combine the Vision Marker Tracking code, with the Blue Line Follow Code (to use the PID control api to help steer the S1). This can be accomplished with the Gimbal Lead Mode for chassis translation, but as an upgrade I'll need my Mecanum Wheel algorithm to make the driving more interesting, and if I tweak anything git will track all changes.
2019-7-30
MarkusXL
MarkusXL Posted at 7-30 19:15
Repo updated with new file.
It works, but is clunky.  The S1 will follow the Vision Marker around at low speed only.
Plenty of light needed.  An assistant to move the Vision Marker around and guide the S1 while you monitor the app is helpful.
TODO:  Increase the speed and make the S1 search aggressively if the Vision Marker is lost.  Also tweak the PID parameters for optimum tracking (that's a hard one, plenty of trial and error).
pid_Yaw = rm_ctrl.PIDCtrl()
pid_Pitch = rm_ctrl.PIDCtrl()
list_Marker = RmList()
variable_X = 0
variable_Y = 0
def start():
    global variable_X
    global variable_Y
    global list_Marker
    global pid_Yaw
    global pid_Pitch
    gimbal_ctrl.set_rotate_speed(500)
    vision_ctrl.enable_detection(rm_define.vision_detection_marker)
    robot_ctrl.set_mode(rm_define.robot_mode_chassis_follow)
    pid_Yaw.set_ctrl_params(115,0,5)
    pid_Pitch.set_ctrl_params(85,0,3)
    while True:
        list_Marker=RmList(vision_ctrl.get_marker_detection_info())
        if list_Marker[1] == 1:
            variable_X = list_Marker[3]
            variable_Y = list_Marker[4]
            pid_Yaw.set_error(variable_X - 0.5)
            pid_Pitch.set_error(0.5 - variable_Y)
            gimbal_ctrl.rotate_with_speed(pid_Yaw.get_output(),pid_Pitch.get_output())
            chassis_ctrl.set_trans_speed(0.2)
            chassis_ctrl.set_follow_gimbal_offset(0)
            chassis_ctrl.move(0)
            time.sleep(0.05)
        else:
            chassis_ctrl.stop()
2019-7-30
