Aardvark
Flight distance : 384432 ft
The devices do get cosy during operation, the Action seem to be designed with the front filter ring as a heat sink, along with the grill below the lens, so the fact they get hot means they are doing their job well. I measured the temperature of mine yesterday (one of these laser handheld thermometers), and working at 4k 60fps and Rocksteady on it was sitting at 50C at some points on the front filter ring and casing (ambient air temperature was about 25C). There is even a warning in the manual saying they get hot and you should not touch some parts, so situation normal.
Although it generates most heat when processor running under maximum load, it will still generate a significant amount at 1080P.
I believe the Action has its own thermal monitoring, and will give warnings if it's getting too hot, with some getting warnings to switch off display (to reduce heat generated) when it's getting cosy.
Most devices with high performance processors will have the same challenges for the engineers, I know my 4k dashcam gets very hot at times. So any competitors devices will suffer from the same issues, perhaps even to a worse extent when reading through their forums. |
