Sensor calibration never completes
747 7 2019-7-29
SkyFrame Aerial
I have the "Calibrate Sensors" warning when using the DJI Go4 app on my android device with my Mavic 2 Pro. I have all the latest firmware on my device and the drone and have tried to calibrate the sensors using the DJI Assistant software on my MacBook Pro over and over again but it never completes. I have taken off the propellors and followed all on screen instructions. I go right through all of the sensor tests and the screen just hangs at the completion screen as per the screenshot below. Is there something I am doing wrong or is this a known issue?
Hanging on completeion
2019-7-29
SkyFrame Aerial
It has ensure the aircraft is powered on and connected to the computer in red, which it obviously is, or I would not have been able to get to this point!
2019-7-29
Hi there, may we have the version of your DJI Assistant 2? Any chance to try another computer?
2019-7-29
SkyFrame Aerial
DJI Mindy Posted at 7-29 20:09
Thanks for replying. I am using version 1.2.4 on my Mac. It is the newest version fo mac! I will try to install it on a different machine and run the calibration also.
2019-7-29
SkyFrame Aerial
SkyFrame Aerial Posted at 7-29 21:42
Just ran a callibration on a PC with Windows 10 using DJI Assisstant version 1.2.5. I get the same result!
2019-7-29
SkyFrame Aerial Posted at 7-29 21:58
Just ran a callibration on a PC with Windows 10 using DJI Assisstant version 1.2.5. I get the same result![view_image]
It seems you installed the wrong DJI Assistant 2, the latest DJI Assistant 2 for Mavic 2 should be v2.0.8, please download here and try again: https://www.dji.com/mavic-2/info#downloads
2019-7-30
SkyFrame Aerial
DJI Mindy Posted at 7-30 01:34
Thank you so much. That has definitely done the job. Calibration complete ;)
2019-7-30
SkyFrame Aerial Posted at 7-30 03:24
You are welcome, please let us know if there is any other problem.
2019-7-30
