ArizonaFlyer
Flight distance : 250932 ft
G37 Mavic Pro Posted at 7-30 19:39
Hey Arizona, do you perform pre-flight checks on your drone. I'm new to drone flying but remember doing this step with model planes and helicopters. Also replacing the props after extended runs. Just a thought. Thanks for sharing.
I didn't, but I certainly should have. Using the GPS map record, I was able to locate the exact spot of the crash (the drone fell down the mountainside for quite a ways after the impact), the gimbal (which fortunately and miraculously landed in a small bush preventing further damage), and a missing prop (with zero chips or scratches). Because there were no scratches on this particular prop, I assume that it flew off during the flight, causing it to veer into the cliff. Thanks for your response. |
