GSPro stops at second waypoint during grid mission
1800 3 2019-7-31
fansceff17c6
Flight distance : 1834360 ft
Croatia
I'm doing a lot of mapping missions with a P4P.
It often happens that the drone flys to the first waypoint (beginn of mapping field), maps the first line to the second waypoint (takes the images) but then hoovers at that second pont and won't transit to the next line (to waypoint 3).
I observed that when the drone reaches waypoint 2, the speed decreases down from mapping speed to 0.4 km/h and stays there, allthough the drone hoovers in place. As I could see on other waypoints, the GSPro app needs the speed to be 0.0 km/h to go to the next waypoint.
Sometimes the drone hoovers few minutes and goes on, sometimes I can push it a bit and then it goes on.
This happens only at waypoint 2, eg the finish of first mapping line.
Any help?
2019-7-31
ALIVINGSTON
Flight distance : 154928 ft
We've been having this issue too!   I haven't noticed it just being the second waypoint.  It seems to be random.  So weird.
2019-8-28
fansceff17c6
ALIVINGSTON Posted at 8-28 08:34
Interesting is that, if the drone flies the first line backwards, then it continues normally to the second line without stop.
And if you do several missions in a day, after few missions this issue stops and everything is normal
2019-9-5
djiuser_G55n8vKb70zl
New Zealand
fansceff17c6 Posted at 2019-9-5 02:49
Any progress on this?  I have the same issue. Have to RTH after watching stuck drone with dwindling battery.
Also, could you explain flying first line backwards? How? Thanks. New to this.
2020-1-23
