DJI Digital FPV System: Unboxing and Highlights
6571 28 2019-7-31
DJI Panda
China
By DJI
DJI has redefined the drone racing industry with their new digital FPV System. It delivers lower latency rates, stunning HD resolution, and an immersive FPV flying experience. This revolutionary solution consists of the DJI FPV Air Unit Module, DJI FPV Camera, DJI FPV Goggles, and DJI FPV Remote Controller (RC), each packed with incredible features.
Here, we will be unboxing the DJI FPV System and revealing everything that comes with the standard box. We will also be highlighting the specs and features that make this product the perfect FPV solution.
Unboxing and Appearance
There’s plenty to discuss about the DJI FPV System but first, let’s have a quick look inside!
In the box
The DJI FPV System is equipped with everything you’ll need for your next FPV adventure. Inside the standard box you’ll find:
DJI FPV Camera (4 M2 screws included) × 1
Coaxial cable × 1
DJI FPV Air Unit × 1
3-in-1 cable × 1
Antenna (MMCX elbow) × 2
Goggles
DJI FPV Goggles (foam padding included) × 1
Power cable × 1
Antenna × 4
Headband × 1
USB-C Cable × 1
Sleeve × 1
RC
DJI FPV RC (WB37 battery included) × 1
Highlights
A New Era of FPV Racing
The new DJI HD Low Latency FPV Transmission technology (DJI HDL FPV Transmission), for the first time, provides pilots with remarkable HD resolution and latency rates lower than 28 ms, helping to elevate your FPV experience to incredible new heights!
8 Channels, 8 Drones
With an upgraded transmission technology, the DJI FPV Air Unit is equipped with eight frequency channels, which allows eight drones to fly simultaneously. With each pilot having their own channel, cross-interference is reduced, providing an optimal racing experience. *
* There are up to eight channels for DJI FPV Goggles depending on the region (FCC: 8, CE/SRRC: 4, MIC: 3). Each channel has a bandwidth of 20 MHz. The default channel is eight and only one pilot at a time is allowed to use this channel. All channels operate under a 5.8GHz frequency.
Anti-Interference Digital Transmission
The DJI HDL FPV Transmission technology utilizes a two-way communication system to stabilize signal connections, granting pilots more flexibility while flying through challenging areas.
Smooth HD Image Quality
DJI FPV Goggles support and record in 720p/60fps and feature a 720p/120fps HD live view. This high-quality resolution is paired with latency rates lower than 28 ms, delivering a clear view and fast performance.
1080p Aerial Footage
Capture breathtaking videos in picturesque locations with the DJI FPV Air Unit, which provides pilots with 1080p/60fps recording.
7ms low latency
The latency between the DJI FPV Air Unit and the DJI FPV Remote Controller can go as low as 7 ms, allowing pilots to send flight commands faster and complete difficult aerial stunts.
Integrated Control
4km Control Distance
During drone operation, the DJI FPV Remote Controller can control the DJI FPV Air Unit for up to 4 km, allowing pilots to fly farther with consistently stable signal strength. *
* 4km maximum transmission distance; FCC: 4 km, CE: 0.7 km, SRRC: 4 km.
4-in-1 Closed-Loop Control
The DJI FPV Remote Controller’s closed-loop software allows users to remotely set parameters for DJI FPV Goggles, the DJI FPV Air Unit, and the DJI FPV Camera, increasing stabilization and reducing operational errors.
Dynamic Filming Capabilities
The DJI FPV Camera has a 150° ultra-wide-angle lens, which allows users to capture more landscape into the frame. Pilots can also select from three camera modes (Racing, Standard, LED) to overcome challenges in different flying scenarios as well as adjust screen brightness and saturation to obtain a vivid image.
Accessories that Boost Your FPV Experience
Equip yourself with an array of incredible accessories for the DJI FPV System and its accompanying components.
Click Here to DJI Store>>
The content origins from DJI BUYINGGUIDES
2019-7-31
Dave50W
Flight distance : 341115 ft
Will the race edition goggles work with the new race air unit?
2019-7-31
A J
Flight distance : 12540030 ft
Looks fantastic - was wondering when DJI would enter this market
2019-7-31
Elettrone78
Flight distance : 2380761 ft
This is all very interesting, can the googles and the air unit work separately from the controller?
I mean...what if I want to use another radio whatever the reason...I don't honestly get why the controller...
I'll throw in a couple of examples:
1)pros already love their FrSky transmitters and are unlikely do drop them because it's opensource...
2)what if I want to use the air unit and the googles on an inspire 2 because of the low latency and the immersive view unavailable otherwise...the small Inspire 2 FPV window on the DJI Go4 APP doesn't cut it!
We need more info for this to be appealing.
2019-7-31
ro_flyer
Flight distance : 5445161 ft
Brazil
Looks fantastic - but the price.....
2019-7-31
escore
Flight distance : 461335 ft
Finland
Can the goggles or controller be used somehow with existing DJI drones?
2019-7-31
djiuser_t6eZYl6o1YMs
Wow!  Do these goggles offer an external video input via USB-C?
2019-7-31
jacksonnai
Malaysia
Cool! Nice to see
2019-7-31
DJI Susan
Dave50W Posted at 7-31 06:02
Hey Dave500W, the DJI Digital FPV System does not support DJI Goggles RE.
2019-8-1
DJI Susan
escore Posted at 7-31 11:01
Hi escore, the DJI Digital FPV System uses the latest HDL technology and is not compatible with existing DJI drones, sorry about that.
2019-8-1
DJI Susan
djiuser_t6eZYl6o1YMs Posted at 7-31 14:47
Hi there, the DJI FPV Goggles do not support external video input via USB-C.
2019-8-1
DJI Susan
Elettrone78 Posted at 7-31 10:22
Hi there, DJI Digital FPV System is not compatible with third-party controllers, but you can mount your remote controller receiver to the flight control so that a third-party controller can be used with another transmission system. However, if you use the third-party controller, I'm afraid that you may not be able to enjoy the ultra-low control delay of 7ms and the complete DJI FPV digital image transmission product experience.
Also, the system is not compatible with Inspire 2 for now. Appreciate your support and attention.
2019-8-1
djiuser_C8VZsixBn12q
Hi,
Does the headset have head tracking ?
Are the CE / FCC mode configurable with software or are they two different hardwares ?
Thank you,
Arnaud
2019-8-1
A J
Very cool looking set up
2019-8-1
Woe
Flight distance : 4096506 ft
When will DJI produce it's own racing drone?
2019-8-1
AntDX316
Flight distance : 2982907 ft
CE: 0.7km
If anything they should be some sort of augmented Geo-fence because you can't really RTH when you lose signal from getting carried away.
2019-8-1
Charmande
Flight distance : 299459 ft
Curious to see when the corrective lenses for the goggles will come out. They're mentioned in the product hardware video but there's no page for it in the store.
2019-8-1
skyblu
Switzerland
Interesting, but given the price point, DJI's seriously lagging repair service and historic non-availability of cheap spare parts might make this dead in the water..
2019-8-1
AntDX316
Attaching some NVIDIA Jetson AI to the downlink feed would be cool.
2019-8-2
CristianFed
Norway
Hi, did you get any answer for this question?
2019-8-4
maddox
Malaysia
Nice to know the information
2019-8-4
escore
Finland
CristianFed Posted at 8-4 04:26
"Hi escore, the DJI Digital FPV System uses the latest HDL technology and is not compatible with existing DJI drones, sorry about that."
2019-8-4
Gama-gama
Woe Posted at 8-1 09:13
They pump out products randomly so the answer would be... one day, one day!
2019-8-9
Woe
Gama-gama Posted at 8-9 07:49
this is very true
2019-8-9
Montfrooij
Flight distance : 1859961 ft
Very nice to see!
2019-8-12
David Martin Graff
Flight distance : 34614662 ft
Nicely done - thanks again for sharing!
2019-8-24
Shervin Koushan
Flight distance : 196037 ft
I love how the helmet looks
2019-9-27
McDiver
Hi! Will it be possible to get the video on a external monitor?
2019-10-9
djiuser_FceB34F2zCZl
Elettrone78 Posted at 2019-7-31 10:22
You can use Frysky and whatever you want at least with radios. You probably know that by now. I just switched from fly camera drones to fpv and since I didn't already have a bunch of analog gear like zero amount so I just started fpv with the digital. I like seeing well while flying and its not anymore expensive if your starting from scratch. Looking back it seems like you dont really have to learn to fly camera drones with altitude hold/gps etc. You just have to learn the controls and you can fly. Fpv is much more difficult and a lot of fun. The hard part pays well!
7-22 18:28
