Gio_COL
Flight distance : 2608343 ft
Colombia
Hello Our company Manages a fleet of 6 M600Pro each of them with two battery sets (12 TB47S per unit), We are really concern about the very low perfomance of the batteries showed from the begining, nowadays the batteries has been used more or less for a 110 cycles and the flight time is near 15 minutes, total charge capacity is around 2600mAh from 4500mAh nominal capacity, and the mayor observation on this batteries is that the capacity is not determined by mAh measure during charge as should be, instead of thar is determined by the charging cycles making the batteries underperformance real capacity.
isn't that practice called scheduled obsolescence? and if DJI promises 300 cycles, How will this batteries perform on 100 cycles more? Drone starts motors fly a minute and then land? is this a firmware bug or error?
