My DJI Mavic air will take in imagery of dark or bright green colors and render them grey to the card.
Settings: 4K 24, D-Cinelike, 0 on sharpness, -2 on conrast, 0 on saturation, manual WB to Cloudy or Sunny per enviroment, ISO at minimum 100.
2 pictures are attached for reference, and...
Here is a video link to see the clips:
First shot has a background a horizon of Alder and cottonwood short trees, green in the heart of an Alaksan Summer. Second shot has a background of evergreen trees, which are always green in real life.
You will notice that the evergreen trees have turned a grey color, the same as the fireman's turnout jacket oddly, which is grey in real life.
Was the white balance set to AUTO? I recommend always to put on the SUN, and if necessary, do the color correction on the post-processing. Wasn’t it scary to fly next to metal structures?
Vofas Posted at 7-31 23:16
No, I wrote above the WB was set to Sunny or Cloudy per environment. I turned up saturation and green channels to over 300% in post and there is no green color data at all in the trees. 100% GREY.
your in D-cinelike and low ISO while under exposed. D-cinelike is not processed very much designed for color grading in post not an out of the camera ready to go color profile. plus it is under exposed by 1 to 1.5 stops i think so with low ISO and under exposure and flat color profile its going to struggle on such a small sensor without post processing and color grading.
try it in normal color profile, and auto shutter, ISO, etc and 0/0/0 for sharpness, saturation and contrast. and see if it fixes itself or is closer what you expect..
if you dont want to color grade, select "normal" color profile and go from there.
HereForTheBeer Posted at 8-1 18:28
Actually, on the Mavic Pro at least, the Normal profile boosts green -- for a neutral profile, choose True Color.
Ex Machina Posted at 8-2 04:53
ya, mavic pro has a different image processing pipeline though.. but he mentioning the mavic air and shooting in d-cinelike which is fairly flat. mavic air only has normal and d-cinelike.
I actually have tried it in regular rec 709 mode or whatever the non d-cine mode is. It still takes out the greens. I also went out and over exposed yesterday and the greens were still mostly gone.
As for post color correction, I've taken the shots shown above and cranked them all the way to infinity and there is 0 green data in there, it's crazy.
Beau Posted at 8-6 07:11
my mavic air over saturated greens and reds in "normal" color profile on the drone... and d-cinelike was dull and grey and looked like lost some color data but i could somewhat recover with davinci resolve color grading.
the same problem here, only in raw it manages to capture all the colors. I think it happens only in some copies, I had the opportunity to record with another air and the problem is not so exaggerated or simply is not.
