DJI Digital FPV System Release Notes (08/02/2019)
5195 6 2019-8-2
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.07.31
  • Air Unit Firmware: v01.00.00.00
  • Goggles Firmware: v01.00.00.00
  • Remote Controller Firmware: v01.00.00.00
  • DJI Assistant 2 (DJI FPV Series): v2.0.0
What’s New?
  • Added ability to set the storage mode of the air unit or the goggles as Overwrite or Stop When Full.
  • Added ability to set the protocol between the air unit and flight controller as Normal (S.Bus) or DJI HDL.
  • Added display for public channel (CH8).
  • Added firmware detection. A prompt will appear on the goggles if the firmware of the air unit, goggles and remote controller are not the same version.
  • Fixed occasional issue: the remote controller was unable to unlock a third-party flight controller.
  • Removed alert when the remote controller is in the public channel.
  • Optimized the screen display when entering live view.
  • Optimized the loading speed of files when entering playback.
  • Optimized the battery level detection of the goggles.
  • Optimized the viewing experience in Audience mode.
  • Optimized the screen display of remote controller during calibration.
Notes:
  • Restart the air unit, goggles, and remote controller once the update is complete.
  • Make sure that the firmware of the air unit, the goggles and the remote controller are in the same version. Check the firmware version Setting, then Device Info, and then Device Info on goggles.
  • If the firmware update fails, restart the device and DJI Assistant 2 (DJI FPV Series), and try updating again.
  • Restart the air unit after setting the protocol between the air unit and flight controller.
2019-8-2
Ben Egan4
Is it possible to be able to connect the FPV remote to use on an FPV simulator on computer?
If possible, how can we connect for such use?
Thank you.
2019-8-11
fans9ff6aa5c
I’m having a network error “3-3” in the fpv assistant 2 program and can’t update my firmware. The remote current has firmware listed as “0.0.0.0” and shows nothing for the air unit and goggles.
Any recommendations?
2019-8-11
djiuser_UlVu4I172My6
Hi, do you know when betaflight gps support and rssi will be integrated ?
2019-9-2
djiuser_gKdi4SVUeB0C
please do allow us to set the low battery alarm voltage of thr googles manually. 18650 cells can go much lower.
great system!
2019-10-13
Any hints on when and what we can expect for the next release?
2019-10-15
RGMGFitness
Flight distance : 233757 ft
Ben Egan4 Posted at 8-11 19:32
Not sure if you already have your answer but I did a video on this the other week.
2019-10-22
