fansfe82067d
If you step through frame by frame, each frame is pin sharp despite the motion. I don't see any "rolling shutter" effect, which would be expected (for instance) to vertically distort the fence/balcony posts in the video. I suspect the actual shutter speed is much higher than you think, which means there is no motion blur, and the eye perceives the video as a series of snapshots, not a smooth transition from one frame to the next. Perhaps try taking the same kind of footage with the camera set to fully automatic with no filter, and then see whether the changes you are making manually improve on the automatic settings or not. |
