djiuser_VNsIzQFtAJ4l
Ukraine
DJI Tony Posted at 8-28 08:19
Hi, thanks for the inquiry. The dimension of the remote controller that could support mobile device is Max length: 160 mm; max thickness: 6.5–8.5 mm. You could connect your mobile device by installing it to the remote controller's clamp and use the appropriate cable that you need. For further check, please see the screenshot below. Thank you for your support.
[view_image]
Я спрашиваю о программном обеспечении, которые не работает , оно просто сворачивается при попытке подключения к Mavik zoom . Что делать?
