LAANC Abuse
914 4 2019-8-2
Rogue Medic
Flight distance : 205262 ft
I doubt that this will be the first or last rant on this note. I recently had a SPARK replaceddue to a hardware issue and I am ata loss that after being returned the device is restricted from flying in Class G Airspace. Due to the update of the LAANC requirements, which is understandable, I have notified DJI multiple times and have been ignored that I am in Class G Airspace. However I am informed 1 time that I need toapply for a LAANC. This is ridiculas to me as I am 20 miles from the airport or any form of controlled airspace. Yet the irony is driving to a nearby town where I am closer to the airport the device works just fine. I have provided DJI screenshots of my location and the distance from the airport. I have never seen such abise from a company violating the law. 14 CFR Part 107 indicates the need for a LAANC when operating in or near controlled airspace. Is itme or is 20 miles away excessive even when the FAA says I am clear to go. I love how this has been ignored by the represenatives of DJI. Short of returning the device and finding a different company to go with appears to be the only option that has built out of this frustration.
I am open to any suggewstion from others. Unless your suggestion is to notify ATC at 20 miles away where there is not controlled airspace. They will not give an approval for that because there is no controll there on their end. Obviously with DJI represenatives ignoring the problem through Support I am posting here for other options and maybe a resolution from a moderator.
Aslo I am a 14 CFR Part 107 Licensed Commercial Pilot so I am very aware of the requirements of operating a drone in any class of space.
2019-8-2
scoble08
Flight distance : 4327592 ft
Purchase nolimitdronez.
2019-8-3
Tentoes
Flight distance : 6018255 ft
hehe
I just asked for authorization to fly 75ft high at my new habitat. LAANC said, "You're out of your mind!" in big white letters on red background.
I already knew that, but I wasn't going to go higher than the trees.
I took that to mean, "No."
2019-8-3
sky_makai
Flight distance : 3397539 ft
DJI needs to pay attention to LAANC and provide a solution for 14 CFR Pt. 107 pilots.
2020-6-10
DeafMacBoi
Flight distance : 7848 ft
sky_makai Posted at 6-10 12:24
I agreed with you
2020-6-20
