Matthew Dobrski
Flight distance : 1831050 ft
AntDX316 Posted at 8-6 06:53
It will work if you don't take that many horizontal shots and pull it back far enough so that's cheating. You can try sliding the drone but a slight change of altitude will ruin the shot. I'm not sure if an RTK drone is more accurate on the vertical data.
I did not have time to frame because someone was kicking me off where I parked while it was in the air.
No, this is not true. The process of gathering rough material is identical every time: the drone is hovering as steady as possible, the camera is taking a sequence of images accordingly to your settings. How do you stitch these images in post is the deciding factor. If you want to achieve 360x180 spherical panorama for further viewing in dedicated viewer, the resulting stitched image will be distorted exactly the way you see on your "Field of some kind" photo. Bottom part, usually stitched off 4 images + 1 nadir image, will be absurdly stretched. If you, however, want to achieve more realistic stitch of just a section of this same panoramic view, you must employ different projection algorithm, not spherical. Mercator works fine, fisheye as well ...
BTW, the sample city image is seriously illegal in the light of drone regulations. |
