CemAygun
Turkey
In your case, you already need iso 800 for your desired shutter speed (1/50th is only slightly brighter than 1/60th). Then when you drop to iso 100, which is 3 stops (= 8 times) darker, inevitably your video will get dark.
ND filters are for cases where there is so much light, even with the darkest (and clearest) iso setting, which is 100 for the osmo pocket; you cannot get down to 1/50th (or 1/60th) shutter speed without getting the exposure blown out. Not when there is so little light that you already need a high iso like 800...
Hope this helps,
Cheers,
PS: Your Osmo Pocket is perfectly normal, don't worry
