Flycaster
If you can get airborne for about 5 minutes, you can check the prop tracking by hovering at eye level,
And looking at each prop, while in a hover and at a safe distance, say 5 feet away, and you will see how they are tracking.
They should be tracking in one single flat plane. Edge on view should be flat, without any "visible wobble" as best as I can explain it.
You should only see "one blade thickness" while it is spinning.
If one blade is tracking "higher" than the other, then this can cause a dynamic imbalance.
