Where are the update notices?
501 1 2019-8-7
Airheadbit
When I launched DJI GO 4 I had a pop up that told me a new version was available 4.3.24 (currently 4.3.20) but what was fixed? Where is this information?
2019-8-7
DJI Tony
Super Moderator
Hi, thanks for the inquiry. DJI GO for Android v3.1.58/ DJI GO 4 for Android v4.3.24 and the higher versions better fit the Android system update, and the application response speed and overall user experience will be greatly improved. However, due to the Android system update, the flight simulator function under the Academy in the app will no longer be supported. Please note that if you need to use the flight simulator function, do not update the app to this version or higher versions. Other functions will not be affected. If the flight simulator function cannot be used due to app update by mistake, please contact DJI to obtain a lower version which supports flight simulator function and install it. Thank you for your understanding and support.
2019-8-7
