Check flight mode
755 5 2019-8-7
PelaRacing
Argentina
Hello! How are you?  Is it possible to make a recording where the drone always focuses on the same fixed point?  Either in normal video mode or tapfly.  I've seen videos where people make flights and always focus on the same place while the drone makes different movements.  Thank you!
2019-8-7
A J
Flight distance : 13926112 ft
On the spark try using the quick shots
2019-8-7
LouisP
Flight distance : 41952 ft
you can set auto track on a stationary object and then manually fly the drone, it will turn to keep the camera pointed at the tracked object .
2019-8-7
S-e-ven
Flight distance : 5922034 ft
Thailand
Get litchi and create a mission with one point/ some points of interest.
Or one of the other apps, that support missions with the Spark, poi, ...
2019-8-7
PelaRacing
Argentina
LouisP Posted at 8-7 11:44
OK perfect
Would it bother you to explain how I set the spark to automatically track a stationary object?
Thank you!
2019-8-9
LouisP
PelaRacing Posted at 8-9 09:30
OK perfect
select 'active track' in the intelligent flight modes, draw a box on the screen around what you want to track, hit go.
2019-8-13
