kfh
Denmark
There is an extra quirk with D-Cinelike, and that is, that the file contains more information in low-light environments. I used 25fps, MP4, 4k, 2.7k and 1080p settings (best quality), with and without D-Cinelike. Here only results for 4k.
With D-Cinelike I got these results:
4k, D-Cinelike
File size : 655 MiB
Duration : 1mn 3s
Overall bit rate mode : Variable
Overall bit rate : 87.1 Mbps
Encoded date : UTC 2019-11-05 15:55:59
Tagged date : UTC 2019-11-05 15:55:59
Comment : DE=D-CLike, Type=Normal, HQ=High, Mode=P
Very to extremely noisy (maximum ISO). Areas with relatively less noise in the following contains far more noise.
4k, normal
File size : 390 MiB
Duration : 1mn 4s
Overall bit rate : 50.5 Mbps
Encoded date : UTC 2019-11-05 16:00:52
Tagged date : UTC 2019-11-05 16:00:52
Comment : DE=None, Type=Normal, HQ=High, Mode=P
Very noisy (maximum ISO), as expected. Especially in the shadow areas.
The difference in content is visibly more noise in the D-Cinelike version (i.e. the noise floor is raised by the altered Gamma). There’s less blown highlights too, so you’ll have to test thoroughly for yourself. The cut images are only for illustration (and in a running video, the difference in noise levels is far easier to see due to the “noise activity level” :-).
In good lighting (completely different scene) - outside, summer, sunshine, Bruxelles National Day 2019, city streets, you’ll get values like these:
File size : 641 MiB
Duration : 53s 739ms
Overall bit rate : 100 Mbps
Encoded date : UTC 2019-07-21 14:08:11
Tagged date : UTC 2019-07-21 14:08:11
Noise is practically non-existent, but the amount of captured detail is high (compared to the first example, where a large part of the “captured detail” is actually noise).
The best way to experience the difference is by performing a simple test yourself, and then apply a D-Cinelike LUT in post (i.e. in LumaFusion on an iPad or Final Cut Pro X on a Mac or DaVinci Resolve on Mac, Windows or Linux). That way you KNOW, how the hardware behaves. It only takes between a few minutes and an hour, depending on your proficiency in handling the tools.
YMMV - have fun. |
