Only 2 plastic fasteners for Gimbal Shock Absorbers?
17418 19 2015-6-8
thill1
When inspecting and organizing my P3 equipment today, I noticed that only 2 of the P3 shock absorbers have fasteners to secure the shock absorbers.
They are diagonal from each other, and the other two do not have the plastic fasteners.
Is this by design?  Or am I missing 2 of the fasteners, which look like plastic screws going through to secure it?
Can someone look at theirs and tell me either way?  I would post a picture, but it was over 1MB, which is too large for this forum.  Thanks in advance.
2015-6-8
BobbyB
Appears to be the norm.
2015-6-8
PhantomHelp.com
Flight distance : 228255 ft
It's by design.
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-6-8
CapitAn
lt's normal. Some folks have added plastic zip ties loosely to the other corners in case of an accident. You can see the factory set-up on pg 33 of the manual.
2015-6-8
salota8550 This user has been deleted
2015-6-8
aburkefl
Flight distance : 78612 ft
That's the same technique that's been used for the Yuneeq gimbal on the Blade 350.
As someone else pointed out, if you want some extra trust/faith, you can put a tie-wrap (or two) through the other two holes. But any extra ties should be somewhat loose  if you tighten them you'll defeat the purpose of those "shock absorbers" on the gimbal mount. Hopefully, all you want to do is provide some extra security for the gimbal and camera.
On the practical side, a really good smack that could dislocate the gimbal is probably going to cause a lot of havoc on the rest of the Phantom!
2015-6-8
foreseason
why zip ties??  My p3p came with two extra plastic fasteners.  Why not just use those?
2015-6-8
labroides
Flight distance : 9991457 ft
foreseason Posted at 2015-6-9 10:47
Because it was designed to fly using TWO only.
The additional anti-drop pins are spares.
It's all there in the manual - around page 33 - last part of the gimbal section.
2015-6-8
foreseason
labroides@yahoo Posted at 2015-6-9 12:03
It's all  ...
It says that "two pins have been mounted prior to shipping".  It does not say that it is designed to fly with "TWO only" and it does not say the other two are spares. If you're going to play the "you obviously didn't read the manual" card, at least be accurate about what it says.
My point was that if you're going to start attaching zip ties to the gimbal, you'd probably be better off using the actual clips instead.
I've been using all four clips since day 1 with no problems.
2015-6-10
labroides
DJI have only fitted two to every one of the hundreds of thousands of Phantoms they have made.
Almost every flyer has left it at that.
The manual says .. Mounting the anti-drop pins diagonally is recommended.
How's that for accurate?
They are just insurance and there's no need for 4.
2015-6-10
barryfairclough
Flight distance : 387940 ft
I use two loose plastic zip ties on the remaining two as an insurance.
2015-6-10
ianbradbury34
Flight distance : 218435 ft
Malta
foreseason Posted at 2015-6-10 19:49
It says that "two pins have been mounted prior to shipping".  It does not say that it is designed  ...
I also use all four since day one, and all is good! (guilty...I didn't read the manual...)
2015-6-10
EL SID
I did the same,just installed the two extra ones that were supplied,why not?
2015-8-8
sp.thanos
Greece
the extra 2 pins, may transfer  more vibrations from the Aircraft to the Gimbal.. Thats why they use only two.
On the other hand, i found that vibrations occurred also when flying forward especially crosswinds, because the gimbal touches the VPS module, and the solution on this is to use one landing foam sticker cutted in two pieces and attach it on the dents that gimbal made on the VPS.
https://www.dropbox.com/s/djee8j ... %2033%20PM.jpg?dl=0
2015-8-9
rodger
Flight distance : 20145135 ft
That is what they ship it with. It seems stable with just the 2 inserts. What it comes with works fine. I questioned the same issue and then tried to make it fail. the 2 that it comes with is fine. Not a worry.
2015-8-9
timswimm
that's more then enough
2015-8-9
Dannytidwell75
Flight distance : 398625 ft
timswimm Posted at 2015-8-9 18:02
I dont use the pins at all i use #8x3/4 plastic nylon machine screws with nylon cap nuts its about the same weight and i dont ever have to cut them off if i need to all i have to do is unscrew them....i dont know but it seemed like a smart idea after having to cut my pins and order replacements and you can find them at any hardware store for less than half the price without waiting on ups
2017-5-23
fans6249ca75
https://drive.google.com/open?id=0BztX3pNKznFWVEE2LThHdWpqcUk
2017-7-3
fans6249ca75
2017-7-3
fans9360dd53
Flight distance : 6261161 ft
i got my p3p with two studs fitted , i added the two extras , anyway i had to send my p3p back to dji with a fault nothing to do with the gimbal , and when they returned it  they had removed the two extra ones i fitted  so  since then i have left it with just  two,
2018-5-4
