Alexander Trotsenko
Flight distance : 5804 ft
Russia
I've got some technical problems with my P4P and I need an advice. I use my multicopter alot and when something goes wrong I repare my bird myself. This winter there was very bad crash and looks like it's time when hidden damages show up. I want to ask this questions to make a list of spare parts to replace.The crash. It was in the winter. My tab has got frosen and gone black. I pressed RTH and duaring climbing to the RTH altitude the copter has got in to electric wires. So it fell down on frosen ground from about 15 meters. Thank you DJI drone's shell is designed to save as much as possible. The shell was broken to pieses and the yaw motor cable was teared. Nothing serious - there was only one warning: gimbal motor. So I've replaced the shell and to get back faster replaced the gimbal yaw motor instead of waiting for the cable for it.
After repairing there were no problems for several months. Then I noticed that two propeller mounts are broken. I've replaced them and that was an epic fail - I've bought fake mounts. Hell is waiting for the seller - one of this mounts has crumbled in the air so there was another accident. Not a real crash - the MC has done emergency landing from 60 meters down to a box with sand. I was shooting a building process ang there were a lot of bare concrete, but that day I was lucky. After a good clean I've foud genuine mounts and the MC is in the air again.
Four months later I've got this problems.
1. Left rear optical sensor communication error. In the Assistant 2 left rear camera is blank. I'm going to replace the sensor. Is it a sensor problem or it may be a control board?
Maybe I'd better swap sensors and watch the overall status?
2. The gimbal behavior is like it does not get the copter's IMU information. I know how the gimbal works when it is powered on whith no MC connected - it does stabilise, but when it's been tunerned, it's motors move very slowly. And this is what I observe now. The camera works good, I can move the gimbal up down and it does move left/right when I move the yaw stick. But it does not change it's behavior when I toggle FPV/Follow in the DJI GO. All the simptoms say that the gimbal does not get the IMU information. I'm happy that this months I take photos, not video. Each time I turn the copter, I wait till the gimbal gets its roll axis stabilised. It does, but it takes about 3-5 seconds. Also the gimbal has no idea where is the copter's heading so the yaw motor is moving slowly too. The gimbal is just like a sloth - it's slow, but it does work. I've used the C-Fixer on both compasses - did not help (but I'm happy I did). I've calibrated IMU on a perfectly aligned surface - did not help. And as the copter's behavior is just perfect now (even better than before the crash), I started to look deeper and I think the gimbal does not get the IMU information. Can you help me? I'm going to disassemble my bird again and observe all the flex cables. I hope the problem can be solved by reconnection, but not sure.
